1998 Ford Taurus Possible Hydro-lock damage
98,000 MILES • 6 CYL • FWD • AUTOMATIC
JDHARRI58
The car stalled while being drove through deep water. At first, hydo-lock was suspected. Each time I'd turn the key, the starter engaged the fly-wheel with a loud click and did not crank the engine. I removed all the plugs and inspected each cylinder for water. There was none in any cylinder. I inspected the air filter and it was wet along with a small amount of water in the bottom of the filter housing. I removed the starter and bench tested it. It worked fine. I re-installed it and the same thing happened initially. After several tries, it began to turn the engine over. The engine finally started and after a few moments of rough idling it zoomed back to life. However, a mysterious loud and obnoxious taping became immediately apparent. It sounds like it's coming from the top area of the engine but it's hard to say exactly where. I changed the oil and filter hoping this might help but the noise is still there. The engine seems to run fine and hasn't exhibited any degradation in performance or thrown an SES light of any kind. It seems to me that if it had a bent rod, collapsed lifter or sticking valves that the engine would run rough and there would be drivability problems as well as an SES light. I need some suggestions on what to do next along with an estimate of what your suggestions may cost. This car isn't eligible for the 'clunker deal' and is was meant to be a seed car for my son whose is on active duty in the army. HELP!
Aug 14, 2009 at 3:21 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Quite possible if small amount of water got into combustion chamber may have broke loose carbon deposits. The rough idle on start up was probably carbon getting stuck to valves as it left out exhaust. A larger piece left behind bouncing around. Therfore no loss of performance. Try some top engine cleaner
Hope this helps
Thanks for donate
Aug 14, 2009 at 5:44 AM
