1998 Ford Taurus Part numbers
AUNTNEATS
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic
So, if the part numbers are the same from year to year am I safe in presuming the part itself has not changed or had any spec alterations?
Dec 26, 2009 at 4:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if anything had changed on the part then the new part number will have an additional digit at the end such as 12345 to 12345-A . they will still produce and sell the older style part in stores though, so you will have to check up at the dealer on whatever part you are buying to match the number they give you to the number the part store gives you.
Dec 26, 2009 at 7:02 AM
