1998 Ford Taurus P0302
1998 FORD TAURUS
10,300 MILES • 6 CYL • 2WD • AUTOMATIC
GOPACKGO
My problem started with a slight shaking at idle. It has progressivly gotten worse so that now it shakes while drivng, but very noticibly at an idle. My check engine light comes on imediatly when i start the engine, but after a few minutes begins to blink. I am getting a P0302 code, which i was told is a #2 misfire. I guess i just dont know where to go from here.
Aug 28, 2009 at 4:04 AM
BMRFIXIT
  • 19,053 POSTS
Misfiring codes
1st step should be a tune up check coil
should not drive if check engine light is blinking
as it may damage catalytic converter
Aug 28, 2009 at 10:40 PM
