1998 Ford Taurus oil pump not working
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
YOUKNOWMYNAME67
  • 25 POSTS
where is the connection for the oil pump? the pressure switch is working letting me know theres no pressure and it happened after i changed the upper intake gasket so i must have unhooked something and plugged it into the wrong place or didnt plug it back in can someone help with a diagram or a picture
Oct 4, 2010 at 11:07 AM
  • 110,248 POSTS
Are you refering to the oil sending unit? If so, is located on the rear of the engine block on top. Here is a picture. It is number 15 on the picture. You may need to enlarge the picture to see it.
https://images.2carpros.com/forum/automotive_pictures/249084_5_79.jpg
Let me know if this helps. Joe
Oct 4, 2010 at 2:23 PM
