Oil light
PIPPY
  • 18 POSTS
Engine Mechanical problem
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic 74000? miles
is it more common for oil light switch to go or more common for oil pump or bearings.
Aug 11, 2009 at 7:01 AM
OBXAUTOMEDIC
  • 3,719 POSTS
Usually with that mileage it is the Switch.
One sure fire way to tell is to test Oil Pressure.
But, if think you can replace it yourself the cost of the switch is only about $10 - $15.
Also, with engine running do you hear any tapping from the engine? If not then I would say that it is the switch.
Aug 11, 2009 at 7:19 AM
PIPPY
  • 18 POSTS
no tapping of the motor. pretty quite lets hope its the switch thank you very much for the input.
Aug 11, 2009 at 7:40 AM
OBXAUTOMEDIC
  • 3,719 POSTS
Know Problem.....
Thats what we're here for.
Let me know the results.
Aug 11, 2009 at 11:11 AM
SHINE TWUZTID
I'm asking about my car through this question because it is exactly what is going on with mine now.
I replaced the switch already and there never was any light to begin with but, there is tapping, and I know there is no oil on the heads because when I put oil onto them, they quieted right down.
So, would i need to replace the pump since the sensor/switch is good?
Oct 22, 2021 at 6:18 AM
SQM
  • 6,383 POSTS
Best course of action would be to test the oil pressure. This way you will know if the pressure is insufficient.
You can install an oil pressure gauge to the same spot where the sensor is.
This vehicle should have 40-60 PSI of oil pressure at 2,500 RPMs.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Oct 25, 2021 at 7:31 AM
