1998 Ford Taurus not sure
1998 FORD TAURUS
BKDAVIS76
Brakes problem
1998 Ford Taurus 6 cyl Front Wheel Drive 104.00 miles
i cant figure out what is wrong with my brakes. when you press down on the brake pedal it goes all way the down with no brake ,but if you pump it as least two more times the pedal starts harding up. cant figure if it's the power booster or the master cylinder.i replaced the power booster not even a year and a half ago so im thinkng maybe its the master cylinder. thanks for the help
Nov 1, 2010 at 1:24 PM
WRENCHTECH
  • 20,761 POSTS
It's definitely NOT the power booster.
Have you lost any fluid or has any work been done to the system before this happening?
What led up to this?
Nov 2, 2010 at 12:15 AM
