1998 Ford Taurus NO START
124,987 MILES • 6 CYL • FWD • AUTOMATIC
BIG LES
I WAS DRIVING MY CAR ON FREEWAY GOING ABOUT 60 MPH. THE CHECK ENGINE LIGHT BEGAN TO FLASH THEN MY SPEED BEGAN TO DECREASE. I COASTED TO EXIT FREEWAY. I CHECKED WITH A OBD2 SCANNER IT SAID CLINDER 1,2,6,MISFIRE. AND CAMSHAFT SENSOR MALFUNCTION. ITS GETTING SPARK AND FUEL. I REPLACED THE PLUGS,WIRES,CAM SENSOR AND TIMING CHAIN(WHICH HAD A LOT OF SLACK). I CHECKED ALL FUSES AND RELAYS. IM LOST ON WHAT TO DO NEXT EXCEPT CHANGE ENGINE COMPUTER. COMPRESSION IS GOOD.WHAT COULD IT BE?
Sep 30, 2008 at 6:47 AM
BMRFIXIT
  • 19,053 POSTS
check fuel pressure
FUEL PRESSURE PSI ???
Oct 2, 2008 at 11:16 PM
