1998 Ford Taurus no heat
LEWPA64
Heater problem
1998 Ford Taurus 6 cyl Two Wheel Drive Automatic 64k miles
the radiator and t-stat are new but there is little heat
the rad. fluid is high. what else can it be?
Mar 5, 2008 at 2:16 PM
EZMONEY
  • 10 POSTS
IT MIGHT BE THAT THE SYSTEM NEEDS TO BE PURGED (AIR) IN SYSTEM.NOT QUITE SURE HOW TO DO IT. CHECK THE TWO HOSES TO THE HEATER CORE (AT FIREWALL) IF ONE IS COOL AND ONE HOT THEN YOU NEED TO BLEED THE AIR OUT OF THE COOLING SYSTEM..
Mar 30, 2008 at 5:39 PM
