1998 Ford Taurus My car won't turn on!
ATXMAMI9
1998 Ford Taurus 6 cyl Automatic 144000 miles
1998 ford taurus. It's not the battery, and it's not the alternator. When you turn the key to turn it on, it doesnt make any noise, no clicks, no noise from the engine whatsoever, but the lights inside turn on, the radio, and the horn work. We took out the starter and took it to get tested and they said the starter was fine! So we have no idea what it is. Any suggestions?
Jun 8, 2010 at 9:33 AM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be the starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Jun 8, 2010 at 10:00 AM
