1998 Ford Taurus Lower control arm removal
GARIMUELLER
  • 7 POSTS
Suspension problem
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic 91k miles
Gotta replacel it, and find that the bolt on the front bushing has been installed from the top.
I can't get the bolt all the way out, as there is a cast member above it.
what's the best/easiest way to move which parts to access this bolt?
thanks
gary
Mar 16, 2009 at 5:34 AM
RACEFAN966
  • 5,029 POSTS
Ok you will need to remove the trans mount and lower that a little. Here is a pic. I hope this helps
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_51.jpg
Mar 16, 2009 at 5:58 AM
GARIMUELLER
  • 7 POSTS
Any suggestions as to getting new bolts? Can't locate ANY in S. Calif. south of Bakersfield. Local dealer says 7-10 days to order.
How about size, might be able to match if I knew the dimensions.
thanks
gary
Mar 16, 2009 at 7:50 AM
RACEFAN966
  • 5,029 POSTS
Sorry I wish I could get those specs but I can't. That kind of info just isn't available to me at all. Does the dealer have any specs on them?
Mar 17, 2009 at 3:49 AM
GARIMUELLER
  • 7 POSTS
The answers I'm getting make it clear most of the parts guys I'm talking to don't have a clue. 4 different sizes so far when I ask, i.e. different dealer, different bolt size. :(
Looking at the car/pic, I need to lower #4 to get the clearance.
Remove #1, then release the front/rear bushing on #4, then lower the subframe(#4)?
thanks
[quote:168d3bed24="racefan966"]Sorry I wish I could get those specs but I can't. That kind of info just isn't available to me at all. Does the dealer have any specs on them?[/quote:168d3bed24]
Mar 17, 2009 at 4:53 AM
RACEFAN966
  • 5,029 POSTS
Lowering number 4 is correct. As for the bolt sizes they just don't catalog that stuff I do wish they would as it would be so much easier but imagine the size of the repair manual if they did. All I could suggest is that if you are missing any of those bolts is go to a salvage or wrecking yard and buy them there.
Mar 18, 2009 at 3:25 AM
