1998 Ford Taurus Intermittent A/C
92,000 MILES • 6 CYL • FWD • AUTOMATIC
MARCUS1055
Hello, I have a 1998 V6 Taurus SE which is having A/C problems. One day I will start the car with the A/C off, turn on the A/C and the A/C will work fine. Later I will start the car with the A/C off and again the A/C comes on. Still later I will start the car with the A/C on and the A/C will not come on. Other times the A/C will work initially, but whether it is on or off when I start the car, the A/C will not come on. It's like there are gremlins or a really lousy Abbott & Costello act going on. There is no cold air and no blower. When it works, it works, though... Could it be a wire or a fuse? I served 20 years in the Air Force, am 90% disabled and haven't been able to find work for 3 years. I have no money and the scammers here in Tampa have averaged $750 a repair over the last 20 years versus $100 in Ohio while I was stationed at Wright-Patt. I am just glad there are folks like yourselves who are willing to share with the less fortunate. Thanks...
May 4, 2010 at 2:35 PM
  • 110,251 POSTS
Is the problem the blower motor not working at times? If so, have you checked the blower motor resister, relay...? Have you checked to make sure the motor has a good ground?
May 12, 2010 at 1:14 AM
