1998 Ford Taurus idle
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMESBOOS
when cold have to give it gas to start, and must keep engine revved up untill its warm or else it will die, once idling on its own has low idle, and when driving acts like it could die any time, and when doing the speed limit, cuts out like its shifting hard
Jan 10, 2009 at 3:36 PM
JGAROFALO
  • 489 POSTS
I would start by checking the system for codes. Your description of the symptoms points toward a throttle position sensor. The computer uses this sensor to indicate that the throttle is closed while starting. With a bad sensor, the computer sees the wrong signal until you touch the throttle. While driving, this sensor is used to determine engine loading. If the computer sees a bad signal, it will default to a safe setting to prevent transmission damage. This setting raises the hydraulic pressures in the transmission and causes hard shifting.
The same bad signal from this sensor can cause both of the symptoms that you describe. If you do not have access to a scanner, you can go to many parts stores and they will scan your codes for free.
Jan 10, 2009 at 8:29 PM
