1998 Ford Taurus heater location
81,000 MILES • 6 CYL • 4WD • AUTOMATIC
DARICE
Where is the heater located on my car? My past cars had the heater directly in the radiator which was in front of the engine. This car is not set up that way. where is the thermostat and how do I access it?
Nov 18, 2009 at 11:05 AM
  • 110,248 POSTS
The heater core is under the dash on the passanger side. If you follow the upper radiator hose to the engine, it ends at the thermostat housing. Under the housing is the t-stat. If you replace it, make sure to drain the coolant or you will have a mess.
What type of problem are you having?
Nov 19, 2009 at 3:05 PM
