1998 Ford Taurus HEATER
125,000 MILES • 6 CYL • FWD • AUTOMATIC
GMINET
not getting heat, flushed heater core, how do i get all air from cooling sustem
Feb 22, 2010 at 12:03 PM
BMRFIXIT
  • 19,053 POSTS
If no heat check heater core hose if both hot remove radio and check blend door and actuator
when flushing heater core make sure that the bypass hose plugged
By pass hose is by the fire wall if you disconnected the heater hoses from the engine side
Feb 22, 2010 at 12:22 PM
