Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Climate Control
Heater
Heater Core
1998 Ford Taurus HEATER
1998 FORD TAURUS
125,000 MILES • 6 CYL • FWD • AUTOMATIC
GMINET
MEMBER
1 POST
not getting heat, flushed heater core, how do i get all air from cooling sustem
Feb 22, 2010 at 12:03 PM
BMRFIXIT
Experienced Mechanic
If no heat check heater core hose if both hot remove radio and check blend door and actuator
when flushing heater core make sure that the bypass hose plugged
By pass hose is by the fire wall if you disconnected the heater hoses from the engine side
Feb 22, 2010 at 12:22 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
