On two recent occassions when I put the car in Park, the engine revved to over 2500 rpms. I was not using the accelerator. Is this dangerous?
Jul 30, 2008 at 12:40 AM
KLSHIEL
✓Experienced Mechanic
2500 RPMs is not so high that it will do anything to the engine. As the problem is it is not dangerous, however it needs to be fixed because whatever is causing the engine to rev could be causing damage, and it may start happening at other times that are dangerous.
