1998 Ford Taurus Engine Died
BLACKDOLL
1998 Ford Taurus
What would make the engined just shutdown, no warning or anything. Everything cut off and the car will not crank. Battery was taken to get fully charged and put back in the car. Still the car will not crank
Jul 25, 2008 at 6:51 AM
KLSHIEL
  • 163 POSTS
Start by checking your fuses. Even if you find a blown fuse and change it you will still need to find out what caused it to blow. If you can get your codes checked at a parts store.
Jul 25, 2008 at 7:13 AM
