1998 Ford Taurus ELECTRIC TORQUE CONVERTER
1998 FORD TAURUS
HMILLER122
Transmission problem
1998 Ford Taurus 6 cyl Front Wheel Drive Automatic
HI, I WENT TO DRIVE MY CAR YESTERDAY. IT STARTED FINE BUT EVERY TIME I PUT IT INTO DRIVE, IT DIED. A MECHANIC TOLD ME IT SOUNDS LIKE THE ELECTRIC TORQUE CONVERTER. IS THIS A POSSIBILITY? IF SO IS THERE A DIAGRAM OUT THERE THAT SHOWS WHERE THIS IS LOCATED?
THANK YOU SO MUCH
Jun 11, 2010 at 9:00 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
Most likely its not
check for vacuum leaks ,check PCV valve hose
check for codes
check and clean IAC valve
Jun 11, 2010 at 9:43 PM
  • CERTIFIED EXPERT
Could be the TCC solenoid-try disconnecting it and see what happens -the solenoid is within the valve body in the transmission
Jun 11, 2010 at 9:45 PM
