1998 Ford Taurus Door Buzzer
168,465 MILES • 6 CYL • FWD • AUTOMATIC
JRAMKEY
When I turn the car off the buzzer inside the car continues to buzz even after I take the key out of the ignition and the inter light stays on. When I shut the door and try to lock it, the door lock will pop back up and the buzzer is still ringing.
Mar 16, 2010 at 5:02 AM
SERVICE WRITER
  • 9,123 POSTS
Try spraying the door latches with a thin lube like wd-40. Open and close the doors to work them and see if that resolves it.
Mar 16, 2010 at 6:12 AM
