1998 Ford Taurus compressor removal
1998 FORD TAURUS
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
PDWORTHY
I bought a compressor bypass pulley and was wondering if anyone had a diagram on the bolt pattern and removal of the compressor. It is a tight fit and I know there are several options on taking the old compressor out. I just wanted an opinion on what the best route would be.
Thanks, Paul
Nov 1, 2008 at 1:03 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
Access is from the bottom, remove the serp belt, then get under the car and remove the four bolts, will drop out...
Nov 1, 2008 at 1:11 PM
