1998 Ford Taurus Car wont start
149,000 MILES • 6 CYL • FWD • AUTOMATIC
ROGERMONCADA777
Car died out and will not start but cranks over fast. ..... I somehow got it started and it drove fine for 2 days but now it is doing it again..... i changed the spark plugs and fuel filter but it is still cranking fast. The car used to lunge forward at stops before this happened. The last time it worked i had it in park and was applying the gas when it stopped working..... the coil is working i had it tested but it seems to not be getting spark. i can pull the spark plugs and see the gas shooting in so i know its getting some sort of gas but what can be causing it not to spark.. I got it started once but only for 2 seconds (i counted) please help me with this problem!!! Thanks...
Jan 1, 2009 at 12:46 PM
JGAROFALO
  • 489 POSTS
Unusually fast cranking sounds like a timing belt or chain. And if the cam is not turning because of a failed timing belt/chain, there would be no signal from the cam position sensor, which the system needs to generate a spark.
I recommend that you start with a compression test. If compression is low, you have a problem with the timing belt/chain. If compression is good, you need to look at the cam position sensor and crank position sensor.
Feb 17, 2017 at 6:55 AM
