I started having a problem with the Taurus idling rough at a cold start up. It runs rough for about 10-15 seconds then picks up runs fine. I changed the idle air control valve, but that did not help. Then two days ago I parked it in the driveway and the next morning it would not move. It showed no problems other than the idle. I have checked the fluid and it is at the proper level. It is red with no burned smell. I shift through all gears with no movement at all. I had my wife shift while I watch the linkage move on the transmission. It is moving fine. If it helps, I am able to push the car no matter what gear I have it in (Except Park).
Jul 21, 2009 at 11:46 AM
