1998 Ford Taurus Car having problems starting
173,000 MILES • 6 CYL • FWD • AUTOMATIC
IMEL04
I'm having problems with my car not starting. It will turn over fine but won't start. I usually have to try 3 or more times for it to start. After it starts, it runs fine. Just been having problems getting it going. I took it to a shop today and they changed the fuel filter, but it is still doing the same thing.
Jan 12, 2009 at 1:32 PM
JGAROFALO
  • 489 POSTS
A pair of suspects come to mind. Cam position sensor and Throttle position sensor.
Start by having the system checked for codes.
A cam position sensor will give a hard start/no start condition because without the input from that sensor, the computer has to guess whether #1 is on the compression or exhaust stroke. This is a redundancy built into the system to prevent a bad sensor from disabling the car. There is about a 50-50 chance of the computer guessing right and starting the engine.
Suspect #2 is the TP sensor. If this sensor gives a reading that is above closed throttle (idle), it puts the computer in "clear flood" mode. This shuts off the fuel to the injectors.
A third and less likely pair of suspects would be the fuel pump and relay. This is relatively easily checked by checking fuel pressure during the hard start/no start problem.
Hope this helps.
Feb 17, 2017 at 6:58 AM
