1998 Ford Taurus Car does not start - intermittent
219,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHARLEYDOG
This is an intermittent problem! Car always starts from a cold start (overnight in a garage). While doing errands, car does not start at times. No clicking sound when turning key; all caution lights illuminate; alternator and battery have been tested and are perfect (has been to garage for this problem twice). Mechanic suggested moving the shift lever slightly within the P range; does not seem to have any effect. It may not start after five attempts but on the sixth attempt starts perfectly.
Mar 25, 2010 at 9:17 AM
MERLIN2021
  • 17,250 POSTS
Follow the + battery cable to the starter solenoid, when the car is acting up, use a screwdriver and connect the terminal the + battery cable connects to, and the small single blur/red wire without unplugging the wire if it cranks now, replace the solenoid. Remove the Negative _ battery cable before doing the replacement, and attach it last! This will protect against accidental shorting of wires.
Feb 17, 2017 at 6:58 AM
