1998 Ford Taurus car died while driving
178,000 MILES • 6 CYL • 4WD • AUTOMATIC
RIDIA28
my car has died twice while i was driving it. the first time it died, i left it over night and it started the next day. i drove it to the shop and it died again, they said the replaced the crank enie shaft sensor or something of that sort. this time i not sure, i left it parked.
Jul 30, 2008 at 6:22 PM
  • 75,988 POSTS
To determine what's causing it -do below to find out if its fuel or ignition problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors
Jul 30, 2008 at 7:16 PM
