1998 Ford Taurus brake light
46,000 MILES • 6 CYL • 2WD • AUTOMATIC
JMFONSECAJR
driver side brake light inoperable. pass/3rd ok.
replaced lamp/fuse #5 (under scolumn). no luck.
Jun 29, 2009 at 1:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Do the back-up, taillight and turn signal lamps work on the driver side taillamp assembly?
Jun 29, 2009 at 2:20 AM
JMFONSECAJR
turn signal and back-up light work.
Jun 29, 2009 at 2:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Ok, the tail and brake lamp use the same bulb called a double filament bulb. Are you certain the bulb is good, and is the correct type for your vehicle?
Jun 29, 2009 at 4:55 AM
JMFONSECAJR
when I pulled taillight panel off< I changed 1st lamp to the left. This would have been good if the lamp to the right did NOT travel with the trunk lid. I changed the signal lamp not the brake lamp. Problem solved. Life builds character!
Jun 29, 2009 at 8:22 AM
