After installing a new alternator, the serpentine belt will not tighten?
162,000 MILES • 6 CYL • FWD • AUTOMATIC
JUICY636
after installing a new alternator, the serpentine belt will not tighten?
Dec 3, 2008 at 9:38 AM
DAVE H
  • 13,383 POSTS
BELT ADJUSTMENT Tensioners are used to automatically adjust belt tension to specification. Belt tension should be about 178-311 INCH Lbs. (78-137 kg). Check belt for fraying. If fraying exists, ensure belt and tensioner are properly aligned. See Fig. 1 . Tensioners will contain a belt-wear indicator. SeeFig. 1 -Fig. 7 . If tensioner reaches travel limit, as indicated by marks on tensioner, replace belt. Ensure serpentine belts are properly installed. See Fig. 8 -Fig. 20 . Fig. 1: Checking Serpentine Belt Alignment
https://images.2carpros.com/forum/automotive_pictures/266999_belt_2.jpg
https://images.2carpros.com/forum/automotive_pictures/266999_belt2_1.jpg
I can't show you a belt routing diagram without knowing the exact engine size of your vehicle ?
Jun 29, 2021 at 3:24 AM
