1998 Ford Taurus 1998 Ford Taurus engine overheating
110,045 MILES • 6 CYL • 2WD • AUTOMATIC
TERRYCUTRER
I recently took my car for an oil change. After I left the shop my car overheated. My fan is not turning so I have been driving it with the a/c on. I checked the inside fuse panel and can find nothing referring to the fan. My motor reads 3.0v6 and I'm not sure what wheel type it is. Any ideas what I can check?
Jan 24, 2010 at 6:57 AM
BMRFIXIT
  • 19,053 POSTS
Check coolant level
place heater fan on high do you have heat ,does it keep it from overheating
check for engine codes
check under hood fuses and relays and fan motors
Jan 24, 2010 at 10:05 AM
