1998 Ford Taurus
XXTATERZXX
  • 1998 FORD TAURUS
  • 6 CYL
  • FWD
  • 189,000 MILES
OK, whenever the car is first started after haven been sitting for a while, engine cold, as it may, the engine is idling extremely rough, and when it is put into gear it is still shaking pretty bad. It doesnt stop until after it has been driven for some time, or the engine has been warmed up. The car has had a complete tune up. We are debating on changing the fuel filter until we know that it is the problem. We have taken it to a mechanic who wasnt very knowledgeable, and he had to take the transmission out. He didnt do a very good job, and might have bent the driveshaft when he was reinstalling the transmission. We have recently found out that he had flushed the radiator out with Drain-o, and we had to replace the Thermostat. Could this problem be a fuel related problem or a problem with the transmission?
Sunday, March 15th, 2009 AT 11:33 PM
BMRFIXIT
  • 19,053 POSTS
Do you have a check engine light on or blinking
I would suspect a misfiring codes
check ignition wires and coil
check PCV valve hoses or a vacuum leaks
Monday, March 16th, 2009 AT 6:37 AM
XXTATERZXX
  • 5 POSTS
No, there isnt a check engine light on, however, I am not sure if that would even mean anything due to the fact that there are some wiring issues that need to be taken care of.
Monday, March 16th, 2009 AT 8:01 AM
BMRFIXIT
  • 19,053 POSTS
Turn key on engine off you should have check engine light on if not
bulb was removed and or wiring was disconnected
still need to have it scanned for codes
Monday, March 16th, 2009 AT 12:48 PM
