1997 Ford Taurus AC Compressor Stays On
JUSTDON
  • 161 POSTS
Rudpro and Justanold helped me get my AC operating and now I have another issue.
When I place the selector on vent or defrost, the compressor kicks on. It doesn't cycle on and off, it stays on as long as I have it either on vent or defrost. The AC lines even get cold and begin to sweat.
I also noticed that the defrost doesn't get very hot. When I put it on floor, the compressor kicks off and the air gets pretty hot. :?
The AC works great now......
Jun 4, 2007 at 2:36 PM
RUDPRO
  • 224 POSTS
I would check the soldering on the relay you installed. I'm not sure how your vents and blend doors work, if they are electric motors or vacuum operated. If they are electric, they may be tied into the CCRM and you may have put too much solder on the relay where it's bridging another circuit. If that's what it looks like, buy a desoldering tool from Radio Shack. It's about $10. It has a plunger you push down, then heat the solder with your soldering iron holding the desoldering tool next to where your heating, push the button and it sucks the melted solder in. Make sure the solder you put on the relay is not too big of a drop where it's bridging another circuit. The circuits are the silver lines on the board.
Jun 4, 2007 at 6:52 PM
JUSTDON
  • 161 POSTS
If the ac operates in all settings except off, vent, and floor, isn't it suppose to cycle on and off?
I really don't want to tackle taking this thing apart again.. :)
Maybe the $35 the junk yard wants isn't such a bad idea.... :wink:
Jun 5, 2007 at 3:14 AM
JUSTDON
  • 161 POSTS
I must apologize to Justanold and Rudpro, When I put my damn reading glasses on, I could see that I had the selector on floor/vent. When I put it on just VENT, the compressor didn't come on..
Sorry guys, I'll wear my glasses next time.... :lol:
Thanks so much for all the assist. It's running great now...
Jun 5, 2007 at 2:11 PM
Suggested Repair
Confirm the climate-control selector is on the intended mode. On this Taurus the compressor runs in floor/vent and defrost but not in vent-only or floor. Once vent-only was selected, the compressor stayed off and no further repair was needed. If the compressor still runs in vent-only, inspect the previously installed relay solder joints for a bridge to another circuit.
Conversation Summary
The owner of a 1997 Ford Taurus reported that the A/C compressor stayed on in vent or defrost, the lines got cold, and defrost air was not very hot, while floor mode shut the compressor off and produced hot air. An expert suggested checking the solder on a recently installed relay for a bridged circuit. The owner later found the selector had been on floor/vent rather than vent only; in vent only the compressor did not come on, and the system was working correctly.
