Tuesday, July 3rd, 2007 AT 3:51 PM
I have a 97 Taurus, 95K, 3.0 L OHV Vulcan engine. It spun a bearing or something, nevertheless, the engine is locked up. In the process of taking the engine out, I have to remove the flywheel-to-torque converter bolts. I can't reach one of the four bolts, even with the oil pan removed. I am toying with the idea of cutting through the flywheel to possibly allow the flywheel to turn. Help would be appreciated. What do you suggest? Thanks for your help. Dave
