1997 Ford Taurus Tight Steering Shake
JAIMAANN
The past day my steering on my car has been really tight. I have checked power steering fluid and is ok. I also notice a shake when i get over 30mph with a squealing noise.. Any ideas on what it could be, and approx cost for parts if you would know.
Thanks!
Apr 3, 2007 at 11:16 AM
PEPPERMRJ
  • 1,158 POSTS
Sounds like you have a few different things going on.
Did you check the serpentine belt and its tensioner? Can cause loss of steering assist along with other ills.
The squeek and shimmy in the front end could be any number of suspension components. Unless you are somewhat experienced in checking ball joints, controll arms, wheel bearings and alignment specs please have the vehicle checked by a pro.
Safety first.
Good luck and let us know. :)
Apr 3, 2007 at 1:18 PM
Suggested Repair
Check the serpentine belt and tensioner, which can reduce power-steering assist. Have a professional inspect front suspension parts such as ball joints, control arms, wheel bearings, and alignment for the shake and squeal.
Conversation Summary
The owner of a 1997 Ford Taurus with 138,000 miles reports tight steering despite adequate power-steering fluid, plus a shake and squealing noise above 30 mph. The expert suggests checking the serpentine belt and tensioner and having a professional inspect suspension components for safety.
