1997 Ford Taurus Stalls When Stopping
Any check engine light?
Last set of wires & plugs?
0141--a malfunction exists in the heater circuit for oxygen sensor 2 in bank 1
0136--a malfunction exists in the electrical circuit for oxygen sensor 2 in bank 1
1742--torque converter clutch solenoid failed on
0122--the input from the throttle position sensor is lower than expected for the current operating conditions
Those are the printouts I got from Auto Zone, but I'm not sure what any of it means or how to fix it.
Regarding the trans code, I would check the TCC harness for being loose or damaged, pull on it gently to see if it feels like it's tight. If it is remove it and inspect it. What trans work was done?
Tauruswheel covered the TP sensor issue, "probably" a bad tp sensor, but....really need a scanner to do testing on it as far as I know.
Suggested Repair
Diagnose the stored codes rather than guessing one part. For the rear bank 1 oxygen-sensor codes, inspect the sensor wiring and check for an exhaust leak ahead of the sensor; if those are sound, replace the right rear oxygen sensor. For the torque-converter clutch code, inspect the TCC harness for looseness or damage, since a locked converter can cause stalling. Test the throttle-position sensor, its wiring, and the PCM with a scanner before replacing the sensor.
Conversation Summary
A 1997 Ford Taurus 3.0L with about 130,000 miles stalls when stopping after startup, then runs without stalling after extended driving but still feels like the engine jumps at stops. The check-engine light has been on for a long time, and stored codes point to catalyst efficiency, rear bank 1 oxygen-sensor circuit and heater faults, a torque-converter clutch solenoid stuck on, and a low throttle-position-sensor signal. Experts recommend checking oxygen-sensor wiring and exhaust leaks, possibly replacing the right rear sensor, inspecting the TCC harness, and scan-testing the throttle-position sensor circuit.
