1997 Ford Taurus will donate if I get useful info
STEVESLITCH
  • 1997 FORD TAURUS
Transmission problem
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic
taurus from stop intermittently will jerk into gear, then rpm will surge almost like its slipping. Fluid levels fine fluid good color any ideas?
Wednesday, August 18th, 2010 AT 10:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
How does it do once it's going? Does it shift fine after the intial jerk? Does the engine ever try to stall on you?
Wednesday, August 18th, 2010 AT 5:56 PM
STEVESLITCH
Actually once it gets going it seems fine, shifts smooth. Doesnt seem to be transmission honestly. Im stumped. Truthfulyyy my gfriend an I are arguing because it seems tohave very few if any probs while I drive it.
Thursday, August 19th, 2010 AT 3:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Is engine light on? Could be a failing sensor such as the camshaft sensor causing the jerking from a stop.
Thursday, August 19th, 2010 AT 1:36 PM
