Water in transmission oil
RICK CINE
  • 1997 FORD TAURUS
  • 6 CYL
  • 55,000 MILES
I have water in the transmission oil in my 97 ford taurus. How could I be getting coolant in my transmission. I can not find any drawing or diagrams to show me how or where the trans cooler is located or works? Any ideas? Is it inside the radiator?
Monday, July 26th, 2010 AT 8:35 AM
  • 109,885 POSTS
The trans cooling lines run through a section of the radiator. If the two are mixing, the problem lies within the radiator. It will need replaced.
If you are getting coolant in the trans, have the entire system flushed.
Wednesday, April 21st, 2021 AT 10:36 AM
