1997 Ford Taurus Shifting?
RYLAINE
  • 1997 FORD TAURUS
  • 6 CYL
  • 136,000 MILES
Last week I started noticing something that seems to be wrong with my transmission. I had just gotten off the highway and noticed in my neighborhood, if I pressed harder on the gas pedal, the RPMs would go up but I couldn't go much faster than 30 mph. I'm worried, but I don't think there's a problem with the transmission fluid, at least there is enough in there. How much would it cost to fix, if it's even something you can tell me from my explanation. Thanks, I appreciate it!
Monday, July 26th, 2010 AT 3:09 PM
  • 109,885 POSTS
If the trans fluid is clean and full and the transmission is slipping, chances are the clutch plates are worn and need replaced. Basically, that means a soft parts overhaul. Average price is around 2000.00. However, I need to know if the check engine light has come on. It could indicate a sensor issue.
Monday, July 26th, 2010 AT 11:52 PM
RYLAINE
So far, no lights have come on. And I drove it today with no problems but I'm sure I'll need to get it looked at asap. I am scared now, but thanks for your help!
Monday, July 26th, 2010 AT 11:59 PM
  • 109,885 POSTS
Don't be scared. Have it checked and let me know what they tell you. I won't let you get taken.
Tuesday, July 27th, 2010 AT 1:01 AM
