1997 Ford Taurus tune up
167,000 MILES • V8 • FWD • AUTOMATIC
KEVINLOKEN
  • 74 POSTS
hey hows it going i know this is a fairly dumb questions but im asking cause im not sure i have a 1997 ford taurus sho v8 and i want to do a tune up what all do i need cause there isnt a distributor cap so do i even need new wires ?or do i just change plugs ?
what r good plugs to use on a ford ?
thanks alot
Oct 15, 2010 at 6:27 AM
  • 75,988 POSTS
To do a tune-up-you must check engine compression if its within specs if not its useless to give it a tune-up till it gets corrected start here-if you want to proceed go ahead and change the plugs with OEM part
Oct 15, 2010 at 6:34 AM
KEVINLOKEN
  • 74 POSTS
is there a way i can do this at home or do i need to go to garage ? and u said oem spark plugs which ones r oem for a ford taurus sho ?
Oct 15, 2010 at 7:50 PM
  • 75,988 POSTS
What is your liter engine?
Oct 16, 2010 at 7:38 AM
KEVINLOKEN
  • 74 POSTS
its a 3.4 litre v8 front wheel drive
Oct 16, 2010 at 5:15 PM
  • 75,988 POSTS
Type of SparkPlugs: AWSF-32FM
REMOVAL
Remove the coil per plug unit.
Loosen spark plugs a 1/4 turn, and using compressed air, remove any dirt or foreign material from spark plug areas of cylinder heads.
Remove spark plugs.
Inspect and, if necessary, replace spark plugs.
INSTALLATION
Follow removal procedure in reverse order.
Tighten spark plugs to 9-20 Nm (7-15 lb ft) .
Oct 16, 2010 at 6:11 PM
