1997 Ford Taurus transmission wont move car
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
MACK GUY
car had been working alright.experienced hard shift once in awhile.made stop at light.take off nothing happens.has plenty of fluid(never used any)has been serviced several times.when moving stick from forward to rev feel slight twinge but nothing else.
Mar 14, 2010 at 9:57 AM
BMRFIXIT
  • 19,053 POSTS
Suspect internal tranny failure and tranny need to be rebuilt or replace
just to make sure that the link and shifter cable all working
engine off key on place shifter in gear (R or D ….)
try and crank the engine it should not start or crank in gear
next step is to check for codes
let me know what you have for codes
Mar 14, 2010 at 11:01 AM
LARRY B NEWMAN
my 03 taurus done same thing. it was a broken pump shaft in tranny. I managed to find a used tranny and have it installed all for $800. I'm sure thats not good news but hope it helps.
Mar 18, 2010 at 9:26 AM
BMRFIXIT
  • 19,053 POSTS
Correct pump and pump shaft very common failure
Mar 18, 2010 at 11:26 AM
