Transmission will not shift into overdrive. Accelerator depressed and Emergency Brake light illuminates. Curse control when turned on, dash light illuminates but speed will not set/control.
Replaced shifter transmitter, checked (removed) emergency brake light switch, WOW what a simple spring loaded contact ..........
Test drive and it doesn't wnat to shift out od first...then did, but still will not shift to overdrive, emergency brake light come on-off, & cruse control still will not work???
Any Ideas??? Speed sensor failure??? HELP....
Thank You!!!!
Thank You!!!!
May 27, 2010 at 5:45 AM
