Transmission problem
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic
My Taurus is either not shifting at all at low speeds, or shifting very hard. I was going between 10-25mph and it either shifts hard or very slow. Also at around 35-40 does the same thing. And when you just try to take off from a low speed to a high one it doesn't shift at all unless you let off the gas. Another thing sometimes when you start the car to let it sit and idle it will act like it wants to die but yet tries to stay started. It doesn't die but act's like its going to.
Apr 24, 2008 at 9:25 AM
