1997 Ford Taurus Low Catalyst Efficiency on Bank 1
126,780 MILES • 6 CYL • FWD • AUTOMATIC
CHLOE'S DAD
catalyst efficiency low-bank 1 explanation the oxygen sensors monitor the catalytic converters ability to store oxygen. probable cause 1. catalytic converter defective (failure possibly due to #2,3,or 4) 2.engine misfire or running condition 3. large vacuum leak 4. engine oil leakage into exhaust-valve guide seals,piston rings. this is the read out of an obd scan. just got a tune up before the scan. any suggestions on where to go from here.thanks a million.
Sep 7, 2009 at 6:00 PM
BMRFIXIT
  • 19,053 POSTS
Check for any exhaust leak before the cat
check O2 sensors if have one new the other an old one may get that code too
Sep 7, 2009 at 11:14 PM
