1997 Ford Taurus system failure will not turn over or start
GRAVEDIGGER
  • 1997 FORD TAURUS
  • 6 CYL
  • FWD
  • 150,000 MILES
The battery is good, changed the starter, cables on tight, but I get the dinging bell when I put the key in but when I try to start the car I get a clicking noise by the battery and no lights come on the dash except for the check engine light will flash in sequence with the click. Then the power cable to the battery will smoke a little and the the fan kicks on. Its like the brain is telling it to do things out of sequence. I am lost when it comes to electrical help me fix this and I will be your biggest fan. Thanks Roy
Tuesday, March 11th, 2008 AT 7:36 AM
BLACKOP555
  • 10,371 POSTS
First ill test the waters here and ask some simple questions see if thers something over looked then we will get more technical.
Did you clean the terminals of corrosion and change the starter solenoid/relay?
Sunday, March 16th, 2008 AT 11:08 AM
