1997 Ford Taurus Won't turn over at all
TWINDOM
  • 1997 FORD TAURUS
1997 Ford Taurus 4 cyl 119500 miles
I drove my car to work tonight with no issues. When I got off work my car wouldn't turn over. The key will turn, all of my lights come on with no dimming, but the car doesn't even click when trying to turn it over. Any ideas what this issue is?
Friday, August 20th, 2010 AT 11:03 PM
Check the battery and connections if okay-start checking the starter, starter relay, transmission range switch and ignition switch. No crank at all/nothing/nada when key is engage to starting position
Could be the starter, starter relay, clutch switch/park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Saturday, August 21st, 2010 AT 3:34 AM
