1997 Ford Taurus Step by Step instructions
HOLLYWOOD24
Engine Mechanical problem
1997 Ford Taurus Automatic
I need step by step instructions on starter replacement?
Jun 6, 2008 at 4:14 PM
MERLIN2021
  • 17,250 POSTS
Remove the negative(-) battery cable, then remove the wires at the starter, remove the two bolts holding the starter, be careful the starter is HEAVY! use caution removing the last bolt. Install is the reverse of the proceedure!
Jun 6, 2008 at 11:10 PM
