1997 Ford Taurus Starter turns for split-second then electr
88,000 MILES • 6 CYL • FWD • AUTOMATIC
GGREUB
Using a correct, tested, new, fully-charged Autolite battery, and with one new ground cable and new battery terminals, and wires/terminals are all tight:
The starter turns for a split-second, and then the electrical system dies. In second attempt to start, battery "acts" likes its dead, however, I have instrument panel lights. Where should I check next?
Mar 20, 2010 at 5:30 AM
BMRFIXIT
  • 19,053 POSTS
And then you have to recharge the battery?
Or wait few and will turn again and if so suspect bad connector terminal remove and check and or replace
Mar 20, 2010 at 11:58 AM
GGREUB
I don't have to recharge the battery, but further start attempts produce no noise, even after a couple waits. I'll replace that connector cable to the solenoid first (before replacing solenoid/starter). Thanks.
Greg
Mar 20, 2010 at 5:30 PM
