Starter problems
111,000 MILES • 6 CYL • FWD • AUTOMATIC
KERRYB
We replace the starter but when we went to put the positive cable back on the battery the starter started to crank without the engine being turned on. Did we put the starter on wrong?
Feb 20, 2008 at 2:12 AM
It is unlikely that you did anything wrong unless you put the battery positive wire to both terminals of the starter. Basically the only way the starter will turn is if the trigger wire has 12 volts. So if you did not do this, then the solenoid on the replacement starter is shorted.
Here are some guides that will help with this issue:
https://youtu.be/5Jd2-wfIKOw
If this was not happening prior to the replacement then I would just take that starter back and have them replace it as they gave you a faulty one.
I attached the process below for replacing the starter in case you need them in the future. Thanks
Jul 11, 2021 at 1:22 PM
