1997 Ford Taurus Starter
202,000 MILES • 6 CYL • 2WD • AUTOMATIC
SEABAB2
I need to replace the starter.
I am a limited home mechanic.
But with some coaching, I know I can do it.
Where is the starter on the 1997 Taurus XL?
Is it a matter of a few bolts and plug?
Dec 1, 2008 at 4:09 PM
BMRFIXIT
  • 19,053 POSTS
Disconnect the negative battery cable and set aside
jack and support the car
locate starter and disconnect wires
remove nut over ground cable
remove two mounting bolts
good luck
Dec 1, 2008 at 10:34 PM
