On my Taurus, at times, usually after about 20 minutes of driving, the speedometer seems to shut off and drops to zero even while traveling a speed, and the transmission then fails to shift properly. If while it is in this condition, I press the CRUISE button on the steering wheel, even with the Cruise Control off, the problem fixes itself for a while, eventually it happens again, and the same process seems to snap it out. Any ideas as to why this is and what I should check to repair this issue?
I called a buddy at the local Ford Dealer who thinks it might be a speed sensor, but I question that only because by pressing the Cruise button leads me to think it might be related to the Cruise Control Servo or Module... what do you think?
Steve
Steve
Nov 10, 2009 at 6:19 AM
