1997 Ford Taurus speedometer and odmeter stop working
1997 FORD TAURUS
200,007 MILES • 4 CYL • 2WD • AUTOMATIC
WALTERKUK
MEMBER
1 POST
FOLLOW
the speedometer and odmeter stop working. is it the vss or the speedometer head and how do i remove each . are replacements available and how much.
Nov 9, 2009 at 1:12 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
suspect faulty vehicle speed sensor (VSS). approximately $90 - $110 for the part, depending on brand chosen. VSS is located on transaxle. disconnect battery, disconnect electrical connector to sensor then unbolt and remove to replace.
