1997 Ford Taurus spark knocks
118,000 MILES • 6 CYL • FWD • AUTOMATIC
TIMBOBFERLY
I am running 87 octane fuel, but under loads like hills I hear it spark knocking. I was told that this engine has a octane plug that you can remove and it will advance the timing. Is this true, and can I remove it myself. They said the knocking should go away. I just recently changed the spark plugs. Thanks Tim.
Mar 25, 2009 at 9:54 AM
  • 75,988 POSTS
Check the knock sensor/s its job is to retard the ignition timing when engine starts detonating/spark knocking also the EGR valve if its not opening Yes you do have an octane plug see item location no. 2 below
https://images.2carpros.com/forum/automotive_pictures/12900_detonating_1.jpg
Mar 25, 2009 at 10:09 PM
